spark
Old Feb 17, 2006 | 11:13 AM
lawnboymelvin's Avatar
Default spark
ok my atc was running good until it stop sparking i wiggled the spark plug wire around and all the wires and it sparked 2 times then stoped its not the spark advance or sparkplug wire i tryed wiggling the wires but still no spark what could it be the coil or cdi box? please help
Old Feb 17, 2006 | 02:36 PM
1bad450r's Avatar
Default spark
My old 110 use to do that every couple weeks and it was always the connection between the spark plug boot and wire. The boot on my wire screwed on and off and it would get loose and gunked up. Make sure you check for shorts in your on/off switch and wires also.
Old Feb 21, 2006 | 09:12 AM
Default spark
ok i checked all wires cleaned them up everything and still no spark?
Old Feb 21, 2006 | 02:46 PM
oldkawi's Avatar
Default spark
Did you change your plug? then check your plug wire, it may be burned out at one end or the other.
If that doesn't work start at your CDI and check resistance forwards through all the connections, including the kill swich and to the coil,
You can get the resistance ranges at deepa.reconranger.com Honda manuals
go through it step by step you'll figure it out preety quick.
Darrel
Old Feb 21, 2006 | 04:46 PM
Default spark
ok i put a new plug in and the one pug wire that was oringinally in it was broke so i put another one in it that i knew worked and still nothin so i will check the cdi box for resistance
thanks for the reply
melvin
Old Feb 28, 2006 | 08:17 PM
Default spark
i tryed everthing and nothing worked until i was checking the wires that lead under the flywheel and the part where to wires attach well one of the wires came loose i poped it back in and she spark like new
thanks for all the replys anyway!
Old Feb 28, 2006 | 10:40 PM
HondaAtcRoxz's Avatar
Default spark
hey melvin did you ever get your hubs off you axle???
Old Mar 1, 2006 | 09:14 AM
Default spark
i havent tryed because my grinder doesent work so its no big deal unless they need to come off
Old Mar 8, 2006 | 10:30 PM
greenray's Avatar
Default spark
try the primary coil on the stator assembly , thats probably what it is. you can get a new one on ebay for about 20-30 bux
Old Mar 9, 2006 | 04:33 PM
Default spark
thanks i had to put the wire back on on the stator and it sparked good
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
