Adjusting valves on Rancher 350 engine
Old Feb 17, 2006 | 12:02 PM
jd3020's Avatar
Default Adjusting valves on Rancher 350 engine
I didn't see this covered on the other valve adjusting threads so I thought I'd make a new post. When I get around to adjusting the valves on my Ranchers, do I need to replace the rubber O-ring in the head cover and the time hole bolt as the service manual says or can I get by with reusing them and just getting another head cover gasket? Or, for those that have done it, are you finding the head cover gasket comes off intaked and is reusable one time?
Old Feb 17, 2006 | 12:35 PM
bangy's Avatar
I have adjusted the valves on my rancher twice now and I havent changed the gaskets yetwith no leaking. But will change em next time I check the valves.hope this helps.
Old Feb 17, 2006 | 12:54 PM
jd3020's Avatar
Thanks for the info, I guess if they look good, I'll resuse them.
Old Feb 17, 2006 | 01:11 PM
ddrumman2004's Avatar
Look at the o-ring and make sure that it's not flat on either side. If not, lube with oil and reuse it.
Old Feb 17, 2006 | 01:33 PM
LittleBill's Avatar
i've done mine 4 times, replaced nothing. you will be fine
Old Feb 17, 2006 | 01:49 PM
jd3020's Avatar
This maintenance business just keeps getting better and better. I'm hoping before too long someone will post that they will just come over and do it for me[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 19, 2006 | 03:44 AM
muddirtsand's Avatar
I have done my valves also. All I do is put a little oil on the gaskets. I have not had any problems. Although I would be safe to say after a few times you might want to change it just to feel better about it. Sometimes thats what I do. Ill replace something just to give me a better feeling about things.
Old Feb 27, 2006 | 10:26 AM
thundercat's Avatar
How do you like your 4/2 Ranchers?--Mike
hugemoth
Jul 20, 2020 03:28 AM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
bikedad3
Jul 2, 2015 02:15 AM
