LT80 Jetting
Old Feb 17, 2006 | 08:38 PM
Quad4Fun's Avatar
Default LT80 Jetting
Hi guys,
I've got a PM into Jack, but thought I'd check out here as we have practice tomorrow.
I'll make it quick and easy.
I'm having issues with a 20mm carb and going to try to put a stock carb on (that appears to have been ported).
If you have a Moore built motor with a Trinity pipe and a STOCK carb
<u>What jetting are you running???????
What air filter setup do you have? </u>
Is the Reed block modded at all </u>(I do have a Reed that Jack made)
Thanks a Bunch
Old Feb 17, 2006 | 09:19 PM
Uptmor250r's Avatar
I have a Jacks motor but with a stock pipe the polit jet is 20 and the main is 87.5 to 90 . Hope that helps.. Uptmor250r
Old Feb 17, 2006 | 09:33 PM
Quad4Fun's Avatar
Thanks, I may just try a couple different jets and see what happens.
They sent me different jets with the Trinity pipe, but I can't read what the pilot jet size is.
I'll trudge along.
Thanks a Bunch
Old Feb 18, 2006 | 02:24 AM
Quad4Fun's Avatar
Anybody got a starting point for the jetting with a Trinity pipe......
I think I have a 87.5, 90, 92.5, 100, 115, and a 77.5(not sure what that would be for????)
Old Feb 18, 2006 | 09:47 AM
hateful's Avatar
we have moore motor and running 37.5 and 77.5 main jet on stock carb with uni filter and stock air box worked great the trinity pipe didnt cahange jetting as we went wit h that later .
Old Feb 18, 2006 | 11:14 AM
LT80's Avatar
LT80 Expert
Stock carb:: 37.5 and 77.5
20mm carb: 48-58 pilot and 115-125 main
Old Feb 18, 2006 | 01:20 PM
Quad4Fun's Avatar
Jack,
Any ideas on why the 20mm won't run at idle?
It just dies when you let off the gas.
I've tried 50 and 52 pilot jets. Could that be part of it. Do I need to go bigger??
Old Feb 18, 2006 | 03:35 PM
hateful's Avatar
the 20mm carb has an idle screw on it maybe you have to turn it in .we had that prob with ours
Old Feb 18, 2006 | 09:49 PM
Quad4Fun's Avatar
We tried that, tried everything I could think of.
the pilot jet was only a 50, not sure if going up to a 58 would make a difference.
Pulled the 20mm of anyway, put the stock one on.
I found a 37.5 and a 77.5 in my box [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
A buddy had a brand new stock carb he pulled off, so I have that [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Got the stock carb on, seemed to run ok....
But, it died on the first practice and I can't get it started.
It's kinda making a noise I can't describe, which Ashley said started right before it died on her.
It's getting fuel, it appears to have compression, plug is not fouled.
It has spark, kinda I think, gonna change out some of that stuff to see if it'll get better.
We'll see..........
Old Feb 18, 2006 | 11:39 PM
Uptmor250r's Avatar
I was wrong with the pilot jet was 37.5 and the stock carb. was a 20. I have a question why is my main jet so high. Is it because of the bore of the cylinder, the compression,and altitudewhere we live. I still think that it still lean. Are do i have a seal leaking.[img]i/expressions/face-icon-small-confused.gif[/img]
Uptmor250r
ReconBayou
Oct 31, 2022 05:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
merryman
Sep 19, 2015 03:15 AM
