Will an edelbrock carb work
Old Feb 24, 2006 | 08:34 PM
thedieselkid's Avatar
Default Will an edelbrock carb work
I just got my hot rods crank in the mail today,it is a +4 mm stroke. I plan on keeping my 102 mm bore for now, and using my JE piston that I already have now, I talked to an engine builder and he said it would work If I used a 2mm spacer on the botom of the jug. But my question is can I use an edelbrock carb for now, it would only be temporary until I get a set of 39 mm fcr carbs. I just need to know if that carb is big enough for that motor.
Old Feb 28, 2006 | 04:17 PM
maddog56's Avatar
For all the work you're going to have to do getting a longer cam chain and altering the timing for the spacer I'd just buy the Hotrods spec CP piston and be done with it.
The edelbrock will work, but why not just use your stockers? They have sufficient flow for that setup, and certainly more up top than an edelbrock does.
Old Feb 28, 2006 | 04:42 PM
fizzak's Avatar
Yes it will work, the carb comes factory set for stock 660 with pipe. You will probably have to install the bigger (rich) needle that comes with the kit for that 720. Unless you have cash to burn, why not just wait for the FCR's?
Hankey Pankey
26
Oct 18, 2020 03:50 PM
robj
Jun 15, 2015 08:45 PM
DOAinNY
Jun 11, 2015 10:34 PM
jayking232003
Jun 9, 2015 02:54 PM
400exalltheway
May 19, 2000 05:39 PM
