LT80 starting problems
Old Mar 1, 2006 | 11:10 AM
Halestorm's Avatar
Default LT80 starting problems
Hi im new to the forum and I'am having some troubles with my sons LT80. it will start and run for about 5 -10 minutes then it just dies. i'll try to restart but the engine will just turn over with no signs of starting. i then let it sit for a couple of hours and the bike will start again and run for 5-10 then die again any idea's .
thanx for the help.
Old Mar 1, 2006 | 11:31 AM
Hymis's Avatar
Kinda sounds like a fuel problem. Did you check the to make sure the carb is getting plenty of fuel?
I use clear fuel lines with a fuel filter so I can see if fuel is flowing. The carb might be gunked up or your spark plug may be bad.
Old Mar 1, 2006 | 11:34 AM
Halestorm's Avatar
Ya checked both. the only thing im thinking is that it could be the battery. the battety has to be charges before it will start.
Old Mar 1, 2006 | 12:25 PM
LT80's Avatar
LT80 Expert
I'm thinking electrical.
When things heat up and quit, then cool down and run, usually a stator/coil problem.
The battery not charging may also lead you to the stator.
I'd pull the flywheel and sand/clean the flywheel/stator.
Old Mar 2, 2006 | 11:20 PM
Irunwire's Avatar
Check the engine compression. Mine did almost the same thing and had low compression. Its worth a try.
clsharky
Jun 8, 2015 11:38 AM
Dieseltrash
Jun 6, 2015 09:53 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
