start in gear feature not working
Old Mar 1, 2006 | 08:54 PM
rango726's Avatar
Default start in gear feature not working
i realized the other day the when i step on my rear brake the brake light doesnt come on and also my start in gear in feature wont work on that brake but works fine on the front brakes any ideas
Old Mar 2, 2006 | 07:56 AM
CrashinIt's Avatar
is it on 04 650? The rear brake on that year sucks. I ended up just taking out that caliper completly. I had the same problem.
Old Mar 2, 2006 | 08:49 AM
mudslinginfool's Avatar
Does it in the Mud!
i did the same as crashinit. i took it out. all it did was rattle and not work. the start in gear only works useing your hand brake lever not the foot. unless they have changed that now.
Old Mar 2, 2006 | 10:42 AM
Bear4570's Avatar
The switch is bad on the foot lever. It needs to be changed out. As to the rear brake not working, when you first got th machine did you burnish the foot brake like you did the fron't brakes. If not, it's not gonna work for crap. My foot brake will lock up the rears.
Old Mar 2, 2006 | 12:35 PM
petroleumboy's Avatar
I've had the same problem. Like Bear says, check the harness. Mine was completely broke off when it happened to me. there about 20 bucks to replace and takes about 2 minutes to change out.
Old Mar 2, 2006 | 06:53 PM
rango726's Avatar
my bike is an 06 400 fis auto and its not the actual brakes that arent working its the brake light on the rear pedal but thanks for the info i just dont feel like bringing it back to the dealer for something stupid ill have them order the part and ill put it in thanks again
Old Mar 2, 2006 | 08:13 PM
Rango,
I've had your problem. And like you said, the breaks work fine, just not the tail light and it won't start in gear. Like Bear said, it is the cable. It is found just inside your rear wheel well behind the foot brake peddle. Mine broke off completely and I had a cable hanging there. Its not the best design. The cable is routed up the frame and has a plug that terminates behind the engine. Its really easy to change. But.... the cable has a plunger style switch on it. It is meant to attach to the frame, and is held in place by a round plastic nubbin. If you have more problems let me know and i'll take some pictures of mine and send them too you.
Cheers
Old Mar 2, 2006 | 08:16 PM
rango726's Avatar
i appreciate it petrol
Hankey Pankey
26
Oct 18, 2020 03:50 PM
txkevin
Sep 21, 2015 02:02 PM
HondaR24
Jul 23, 2015 11:22 AM
Big600twin
Jun 10, 2015 03:01 PM
1000gade
May 27, 2015 12:37 PM
