Freedom 90 ATV Help
Old Mar 7, 2006 | 03:06 PM
dean314's Avatar
Default Freedom 90 ATV Help
Just bought new freedom 90 atv. Ran good for 1 day, and now it won't start. Have good spark at plug. Seems like it isn't getting any fuel. Fuel is flowing from fuel tank. No idle or air adjustments are working. Any advice ?
Old Mar 7, 2006 | 03:53 PM
GMT14's Avatar
Has it been wet recently? I have the same machine and on one occasion run switch above the headlight control was not making contact in the "run" position preventing the machine from starting. Not sure if good spark dispells my theory as I'm not exactly sure what circuit that switch interrupts or engages.
Good luck.
Old Mar 7, 2006 | 04:30 PM
dean314's Avatar
It tries to start with the throtle wide open but then dies. I guess i'll try to clean carb.
Old Mar 7, 2006 | 04:37 PM
GMT14's Avatar
Early on when my machine was new there were times it ran extremely rough, would bog down when the throttle was pressed and then stalled (this all occurred through every imaginable position of the idle and air mixture screws).
I change from the torch plug to a NGK, changed to premium gas with dry gas mixed in, removed and cleaned the carb. The carb was not dirty or clogged but cleaned it regardless.
This solved my problems.
stendori
Aug 14, 2015 12:57 PM
HoundDog06
Nov 16, 2003 12:07 AM
machman41
Jul 22, 2003 03:40 PM
FKNA
Sep 14, 2001 09:53 PM
