89 R motor in 86 frame
Old Nov 13, 2000 | 06:22 PM
rhino99's Avatar
I have a friend who will sell me his 89 250r. I have an 86. I like the way my 86 handles, but his motor has way more power than mine. I already have shocks and whatever on my 86 frame, and think it would be way less trouble to just switch motors instead of suspension, axle, carrier, etc etc etc. So, how does the 89 motor bolt into the 86 frame? I think that the rear motor mounts are somehow different, if so, is it possible to do with little work, or is it a big chore? Which would be easiest, keep the motors in their frames and switch componenets or switch motors?
Old Nov 13, 2000 | 10:49 PM
87_250R's Avatar
the engine should bolt right in the rear motor mount is differant (86 mounts on to swing arm) but should work fine.
Old Nov 14, 2000 | 09:43 PM
mx250r91's Avatar
Yeah the engine mounts from all 250r engines 86-89 (including the 3 wheeler engine) all have the same mounting spots. The only difference between the 86 and 89 frame is the 86 uses 2 brackets which go through the swingarm bolt to mount the rear two mounts, while the 89 has the upper go through a frame mount and nothing through the bottom. So yes it is easily interchangeable.
bmxatv10
Oct 14, 2022 06:23 PM
Valder
Nov 28, 2020 07:38 AM
fd24
Jan 16, 2019 08:59 AM
bigred20653
Oct 2, 2015 10:05 AM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
