06 artic cat 500 manual 5speed
Old Mar 18, 2006 | 01:42 PM
trollwog's Avatar
Default 06 artic cat 500 manual 5speed
Just bought my first arctic cat and want to fixerup. Will a ramsey 3000 winch mount to existing bolt hole in frame or do they require a winch mounting plate? also where do I find aftermarket or factory bumpers, cv boot guards (not the flimsey stock plastic), how about exhaust systems to increase power? Any help would be appreciated! I want to add the new 14" itp wheels and tires , will I lose much power? Any other suggestions? Thanks.
Old Mar 18, 2006 | 01:49 PM
Hoopie's Avatar
You wont loose much power with the wheels but I would go ove a 26inch size. check out my pics. I have one also.
You can get your front and rear bumper at the AC dealer or online. there about the same price. Nobody sells them with discounts that I have found for AC equipment. The cv boot gaurds work pretty good but you can buy metal ones also but be careful because the metal ones can bend into the cv joint and rip it. You can check out articchat.com to see how to do a self exhaust mod to increase power. I dont think there is any aftermarket companies that make it. I can honestly say it doesnt need any more power if your just trail riding and mudding with it. cant answer your winch ?
Old Mar 18, 2006 | 02:22 PM
CATSKINNER's Avatar
The front Bumper/Brush Guard should be all you will need to mount the winch. I think it is all one piece. Not sure about the 3000 lb but I would guess they have the same bolt pattern.
Old Mar 19, 2006 | 03:56 PM
Muddedprairie's Avatar
A honda rancher HMF exhaust will work on your cat.. Go to arcticchat like hoppie said you will see guys there most all with 05-06 500-cats have gone that rt.
Mark
Old Mar 19, 2006 | 04:02 PM
LovesThaDirt's Avatar
I put that same 3000lb winch on my 06 AC 500 with the Front bumper replacement I got from the Dealer. But i had to drill and tap the Fairlead holes a size larger for the bolts that Waren sent with the Fairlead. But other than that Im happy with the winch and bummper i just Rino lined the racks and Front bummper. Hope that helps
kodiacrunner
Oct 4, 2015 11:52 AM
Clint Russell
Sep 25, 2015 03:20 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
