clutch question warrior
Old Mar 20, 2006 | 06:09 PM
iallen4190's Avatar
Default clutch question warrior
hey guys, im new to the forums. i have a 88 warrior and the clutch is starting slip. Im thinking i just need clutch plates. looks to be around 60 bucks for the plates, wheres the best place to buy them? also, i have never rebuilt a clutch before, so i need some intructions if anyone has a good link to some.
ps, what oil do you guys run and how much does the warrior take? thanks
Old Mar 20, 2006 | 06:25 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
You want a new clutch and springs. should be between 40 and 70 bucks. and then a gasket for the clutch cover wich is around 10-15 bucks.
Pretty simple to do. disconnect clutch cable from clutch cover, Roll bike up on its side, undo the 8 or so bolts round the clutch cover, bend the keeper tabs down on the sshaft nut, put a strap wrench on clutch basket, big ratchet/ socket on nut pop it is loose. then indo all the spring bolts being sure to just loosen them all first and then work you way around a couple turns at a time. pull out the clutch hub thingy then remove all the disks and plates and pay attention to the order. Think its a friction ring on top then steel ring then friction and so on. Re assmble like you took it apart. Takes about 30 minutes maybe an hour your first time. Pretty simple though.
Oil I use amsoil 10/40 synthetic in mine. no problems with lube. think its between
Sand Wizards
In the menu on the left click tips & Tricks. then click service manuals.. download the one for warrior 350 and you should be good to go.
Old Mar 20, 2006 | 09:30 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Sand Wizards
just buy an EBC($65? and it's the same thing i run) or TUSK($35 and my buddy runs it in a 70-80hp Passion 10mm stroker motor in his shee) clutch from RMATV...
it is one hell of a b!tch to get it back together tho. and you DON'T need the clutch gasket.. just be careful( we weren't and it was still fine) when you take it off... btw tipo the quad on the side so the oil doesn't go everywhere on your floor(unless you have a shop floor with chemicals all over it and don't give a f$%# both coem with HD springs..
also.. i run 10/40 amsoil in mine too..( best oil i've ever bought)
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
200es
Jul 10, 2015 09:09 AM
