454 shock help
Old Mar 22, 2006 | 02:33 PM
Shouldbeworking's Avatar
Default 454 shock help
I'm in need of any information anyone can give me on finding shocks for the rear of my 98 A.C. 454 I have found the stock replacement but was curious about
what else was out there?
Thanks in advance
S.B.W.
Old Mar 22, 2006 | 03:57 PM
swampyjunior's Avatar
Shouldbeworking,
I seem to remember reading someplace where a fella took the shock and removed the spring and took it to an auto parts store and purchased a shock of the same length. I don't think it ever said what it was. Probably cheaper this way.
I have seen replacement shocks for AC 400 and AC 500 that usually run about $200 each. Bit this usually includes the springs and an adjustment wrench. I think it would be cheaper to replace just the shock but I have discovered that due to the weight of the machine the spring gets weak over time. Following the suggetion of WhoDatintheMud, I replaced my springs with HD springs from Highlifter.com. They are excellent and cost about $150 with shipping for all 4 springs and a tool to install the springs and took about 1 hour to install. Really added new life to the old shocks.
If your shock itself is not leaking you might want to look at replacing just the springs.
Hope this helps SJ
Old Mar 22, 2006 | 04:05 PM
Unfortunately thats the problem, my rear shocks are leaking, the rear springs do seam a little soggy maybe I should do both.
Thanks Swampy
Old Mar 23, 2006 | 02:37 AM
I remember reading in an ATV magazine about a shock made by Progressive Suspension that is specifically designed for utility ATV's. It adds 1 inch to your ground clearence and comes with springs already attached that are supposed to be really good.
I did a search on internet and only found them for a 98-99 Suzuki King Quad and not an AC. But I believe its the same or similar to a 98 AC. They were fairly expensive at about $200 each.
The shocks and spring kits can be found at Highlifter.com as well but no shocks are listed for AC but they have them for Suzuki. I Think you would need to remove you shock and measure it and call their customer service or email them to see if the suzuki ones would fit.
I think the stock AC shocks are about $90 new with springs.
You may be able to get something just as good as stock from an auto parts store if you take the AC stock shock in with you and it would cost you less money. They make them that small for some import cars.
SJ
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
