Honeing a Cylinder
Old Mar 23, 2006 | 07:53 PM
luckyboy's Avatar
Default Honeing a Cylinder
First I was wondering how difficult it is to hone a cylinder sleeve.
Second what does a honeing tool look like. Does it look like a wire brush?
Old Mar 23, 2006 | 11:16 PM
trizinNY's Avatar
I use a ball honer witch type that is the shape of a piston with lots of wires sticking out with little ***** of honeing meteral on the ends. there is another type witch has 3 to 4 bars on it witch are usally 4-5 inches long and is spring loaded to push outward on the cylinder walls and both of these are attached to a cordless drill, use a light oil to coat the stones and cylinder walls and use a slow up and down motion wile spining. these are used for removeing skuff marks and light scraches. not for med. to big scraches that will need a bore.
Old Mar 24, 2006 | 09:00 AM
HondaAtcRoxz's Avatar
This is the hone that i used it worked good. And its not difficult just take your time and dont hit anything in the bottom end then when finished clean motor out very well.
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
