Blaster Rebuild Help
Old Mar 28, 2006 | 06:30 PM
gw2k101's Avatar
Default Blaster Rebuild Help
My blaster recently quit running and after a compression test soon figured out that the ring let loose and scored the cylinder wall requiring me to rebuild. Anyways I called my local yamaha dealer and they want me to bend over and grab my ankles if their gonna do the work. So I went to E-bay. I found a company called Lakes Motorsports and was wondering if anyone have heard of them and how their work is. I was either considering sending them my cylinder and let them bore it out or ordering their 240 big bore kit. If I went with their big bore kit, would I need to upgrade my carb or reed cage or what all parts would I need. My blaster is pretty much stock except for the FMF SST pipe. What do you guys recomend? Here are the links to E-bay.
http://cgi.ebay.com/ebaymotors/YAMAH...25099609QQrdZ1
http://cgi.ebay.com/ebaymotors/YAMAH...26318361QQrdZ1
Old Mar 28, 2006 | 06:40 PM
Dirtydude's Avatar
Are you looking for a cheap rebuild or an upgrade?
You confused me with the "grabbing your ankles" and talk of a 240 kit.
Old Mar 28, 2006 | 06:47 PM
Dirtydude's Avatar
you might check out vitos too
595 gets you a 240 big bore kit 32 hp with jet kit.. direct bolt on no sending parts in but you gotta get a oil inject block off kit which most do anyways:
Item CY240K Information
12 PORT DESIGN- 72 MM BORE- 240 CYLINDER WITH HEAD AND ALL GASKETS ( JET KIT FOR STK CARB INCLUDED.)TRIPLE EXHAUST PORT FOR MORE ARM PULLING POWER- A DIRECT BOLT ON-NO CASE MODS.)--NEW PARTS- NO EXCHANGE- OIL INJECT BLOCK OFF REQUIRED SEE-#BOK200
http://www.vitosperformance.net/BLAS...T%20BIG%20BORE
Beeline08
Nov 11, 2016 04:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
