New clutch or heavy duty springs??
Old Mar 28, 2006 | 08:18 PM
scjshaylen's Avatar
Default New clutch or heavy duty springs??
I have an '00 with a K&N, 22" Mud Machines in the rear and 23" Razr2's up front, 15T front sprocket. I'm waiting on my ODP endcap from OnDunes, and I have the following ready to install: Lectron 46hv, Moose thumb throttle, race ported intake, Big Gun rev box.
My question is can I get away with using the stiffer springs or should I go with a new clutch? I haven't had any slippage problems with the stock one. If anyone suggests a new clutch, which one?
Thanks,
Steve
Old Mar 28, 2006 | 08:23 PM
Goodsound's Avatar
Set a New OEM chassis 4 stroke national record on his OMW DS855 - 3.93 !
with those mods I would say your fine with the stock clutch but you better get the RON WOOD springs.
Barnett is the aftermarket clutch to go with if you get one.
Old Mar 28, 2006 | 10:32 PM
Teebone56's Avatar
Ron Wood 60 percent springs, will make a big differance over stock. When the time comes to replace the stock clutch I would go with the Barnett dirt digger.
Old Mar 28, 2006 | 10:36 PM
FatHolly's Avatar
Both[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 28, 2006 | 11:50 PM
Teebone56's Avatar
Yeah, used the Ron Woods springs with my barnett clutch.
Old Mar 28, 2006 | 11:58 PM
flyinds's Avatar
i would suggest that if take the clutch cover off you should just put in a barnett clutch because you are going to need sooner or later.
Old Mar 29, 2006 | 01:30 AM
scjshaylen's Avatar
Thanks all for the info!
speedbuff
13
Nov 11, 2020 10:16 AM
Lou Domenech
Sep 11, 2015 06:35 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
