WARN 424 Q.
Old Mar 29, 2006 | 12:21 AM
Daranello75's Avatar
Default WARN 424 Q.
My button to select switch into 2 wheels drive doesnt work. The ball bearing are stuck in tho open possition, any way to fix that?
Old Mar 29, 2006 | 11:52 PM
Default WARN 424 Q.
thanks guys
Old Mar 30, 2006 | 03:34 AM
WolvyRida's Avatar
Default WARN 424 Q.
all you need to do is take it apart, clean everything up, put a little grease on the shaft and put it back together. Mine does the same thing after a few muddy rides. There is also an o-ring that seals the shaft that u pull out and push in, make sure it's in good shape. That should fix your prob.
Old Mar 31, 2006 | 01:04 AM
Default WARN 424 Q.
Took it apart, first NO O ring on the Button, second spraied the <B><FONT style="BACKGROUND-COLOR: yellow" face=verdana>Sh^t</FONT></B> out of the ball bearings there stuck in the down possission and wont pop back up!
Jeff Roper
Feb 1, 2022 11:48 AM
toonces
Oct 19, 2015 02:21 AM
panicmanic
Sep 28, 2015 12:59 PM
Erick J. Edler
Sep 20, 2015 05:51 PM
Gtsordo
Jul 22, 2015 01:27 PM
