sheave problem
Old Mar 30, 2006 | 10:05 PM
gtchief's Avatar
Default sheave problem
I was changing my spring and while taking my belt off I scratched the inside sheave of the secondary. There is a little gouge in it and a small piece of aluminum was sticking up. Should I just sand it down smooth as possible in that area and hope for the best? Am I completely screwed and in need of a new inner sheave? Very nervous now; I dont want this to rip my new belt apart.
Old Mar 31, 2006 | 01:10 AM
MadLT's Avatar
I'm not sure if the Prairie uses the same secondary, but you might contact the guy from a recent post that is parting out his prairie (Bumble-bee).
Old Mar 31, 2006 | 12:21 PM
Hayashi's Avatar
I would just smooth out the damaged surface as best as you can and see what happens as you said. That would be the cheapest way to go. Possible problem after doing that could be a jerking motion or knocking noise whenever the belt rides on that exact spot. If that happens, you may need to get a new inner sheave (~$200) or, if cheaper, have a machinist weld in a small aluminum piece and file it down to even out the surface. I thougt about JB weld but it might not last long enough. Anyway try easy/cheap method first before you spend too much $ on it.
BF750 and '05 and later Pairies have a (very slightly) stepped angle sheaves on the drive side and earlier Prairies don't. They are interchangeble though AS LONG AS they are swapped as a set (of movable and fixed).
Good Luck.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
clsharky
Jul 13, 2015 02:07 PM
