95 trx 300 needing a lock nut wrench for the gear box
Old Mar 30, 2006 | 11:03 PM
Dana67's Avatar
Default 95 trx 300 needing a lock nut wrench for the gear box
need some help locating a tool to remove the 60mm lock nut from the gear box on my trx 300. i destroyed the bearing in the gear box and can't figure out how to get it out with out some special tool. any tips out there on rebuilding my rear end or where i can get my hands on a lock nut wrench? thanks - dana
95 trx300 2x4 ( that needs its rear bebuilt)
00 rancher es 4x4 w/ 589's ( that has a bad starter)
02 suzuki 80 (that has no problems! lol)
Old Mar 31, 2006 | 12:59 AM
1988TRX250R's Avatar
What locknut on what gear box? The only nut I can think of thats anywhere near 60mm is the locknuts for the axle. You ask about rebuilding the rear end so I'm assuming the axle locknut is what your referring to. Honda has two special tools that fit the axle nut and lock nut but can be removed w/ a cresent wrench. I can get you the part numbers for the tools Saturday, I'm off tomorrow.
Old Mar 31, 2006 | 10:56 PM
Dana67's Avatar
it's the nut inside the gear box that holds the bearing in place for the drive shaft. you can see it in a exploded parts picture.
Old Apr 1, 2006 | 12:15 AM
JimmyHoffa's Avatar
You can get it OFF with the knuckle busters, but that beast can't be properly reinstalled without the specialty honda tool and a torque wrench. With the tool, you know exactly how much the torque is multiplied by (the lever length), so you can calculate how to set/read your wrench. my $.02. You could always make a one-time-user with steel plate and an angle grinder [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Apr 1, 2006 | 01:07 AM
Dana67's Avatar
sounds like a plan. or i could just take the damn piece to a honda shop and ask if they could romove the piece for me and pay them(if it's not my arm or leg) to install the new bearing. thanks - dana
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
VRRRRT
Jun 27, 2015 09:38 AM
DOAinNY
Jun 12, 2015 02:26 PM
