95 trx 300 needing a lock nut wrench for the gear box
Old 03-31-2006 | 12:03 AM
Dana67's Avatar
Default 95 trx 300 needing a lock nut wrench for the gear box
need some help locating a tool to remove the 60mm lock nut from the gear box on my trx 300. i destroyed the bearing in the gear box and can't figure out how to get it out with out some special tool. any tips out there on rebuilding my rear end or where i can get my hands on a lock nut wrench? thanks - dana
95 trx300 2x4 ( that needs its rear bebuilt)
00 rancher es 4x4 w/ 589's ( that has a bad starter)
02 suzuki 80 (that has no problems! lol)
Old 03-31-2006 | 01:59 AM
1988TRX250R's Avatar
What locknut on what gear box? The only nut I can think of thats anywhere near 60mm is the locknuts for the axle. You ask about rebuilding the rear end so I'm assuming the axle locknut is what your referring to. Honda has two special tools that fit the axle nut and lock nut but can be removed w/ a cresent wrench. I can get you the part numbers for the tools Saturday, I'm off tomorrow.
Old 03-31-2006 | 11:56 PM
Dana67's Avatar
it's the nut inside the gear box that holds the bearing in place for the drive shaft. you can see it in a exploded parts picture.
Old 04-01-2006 | 01:15 AM
JimmyHoffa's Avatar
You can get it OFF with the knuckle busters, but that beast can't be properly reinstalled without the specialty honda tool and a torque wrench. With the tool, you know exactly how much the torque is multiplied by (the lever length), so you can calculate how to set/read your wrench. my $.02. You could always make a one-time-user with steel plate and an angle grinder [img]i/expressions/face-icon-small-tongue.gif[/img]
Old 04-01-2006 | 02:07 AM
Dana67's Avatar
sounds like a plan. or i could just take the damn piece to a honda shop and ask if they could romove the piece for me and pay them(if it's not my arm or leg) to install the new bearing. thanks - dana
jrooker6
Ask the Editor
11
04-21-2016 08:35 PM
VRRRRT
06-27-2015 10:38 AM
DOAinNY
06-12-2015 03:26 PM
Quick Reply: 95 trx 300 needing a lock nut wrench for the gear box
