Kawasaki Mojave Rear Brakes
Old Apr 2, 2006 | 11:08 PM
MudSlinginMojave's Avatar
Default Kawasaki Mojave Rear Brakes
Ok, I recently bought a project quad(1991 Kawasaki Mojave). And apparently the previous owner left it sit outside in the weather. So, the rear disk is has a good rust coating on it. And I can't get the disk off so, I have to use it. Now I purchased new brake pads and installed them and bled the brakes. But the brakes are grabbing SEVERELY! I can barely move the quad with all of my might. Does anybody have any ideas on what could be going wrong here? The caliper also doesn't have the parking brake assembly attached to it anymore, so would it not being there have anything to do with it either??? Any help PLEASE!
Thanks, Matt
Old Apr 3, 2006 | 02:05 AM
toyaddict's Avatar
You might want to check the adjustment for the brake pedal, it is located near the pivot point, and if it is out too far it will cause the brake to drag.
Old Apr 5, 2006 | 08:28 PM
MojaveMark's Avatar
When you put the new brake pads on, did you clean the caliper up good. The pins that it slides on can get real gunked up and keep the caliper from sliding back and forth even if the piston is working right. that is what happened to mine and it took me two sets of pads to figure out.
Old Apr 5, 2006 | 09:07 PM
holeshotz8436's Avatar
did you press the brake piston back in when you installed the pads.....its possible the piston got stuck out and is pushing on the pads all the time......hey toyaddict how does that mojo of yours run? do you have any pictures of it?
Old Apr 6, 2006 | 12:24 AM
toyaddict's Avatar
It scares me, and I think I like it. Yea got pics but can never get them sized right for here.
Old Apr 6, 2006 | 08:10 PM
I tore the caliper apart and cleaned the piston and put it back in, and pressed it all the way in...Still when I push on the brake pedal, they lock up but don't retract?
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
