running a 400 with a battery eliminator
Old Apr 3, 2006 | 12:21 AM
Whitedog's Avatar
Default running a 400 with a battery eliminator
For the last 3 years ive been running my rig with the charge coils removed, because Ive heard that a generator robs power. So Ive been running my tach via a 12v cordless drill battery. Well.... I got tired of screwin around with the battery, and decided to put the charge coils back. --- Heres how I wired it-- Charge coils to voltage reg - voltage regulator -red- to batery elim - ground to frame. My hot wire on tack goes to the positive on the battery eliminator. And the ground goes to the frame as well.
Well, when I ran It today, I smelled the smoke comin from the tack. [img]i/expressions/face-icon-small-sad.gif[/img]
Do I have it hooked up wrong???? WTF!
Old Apr 5, 2006 | 11:36 PM
Whitedog's Avatar
BUMP
Let me try to be more clear here. The two yellow wires from the generator go to the voltage regulator, then the red wire from the regulator goes to the battery eliminator. I come from this connection to the positive wire on tha tach. I have a wire from the NEG on the eliminator to the frame. And I ground the tach to the frame also. I dont have a ground wire hooked up under the charge coils, could this maybe be the problem?
Also, the ground wire from the battery eliminator To the frame broke at the connector, just before the tach smoked.
Maybe this fried it! ??? Makes sense now....
Old Apr 6, 2006 | 11:10 PM
16polaris's Avatar
I have had 2 brand new tachs on mine and they neither one lasted a night at the races. I dont have a battery or an eliminator, could that be the problem with my tachs breaking?
Old Apr 6, 2006 | 11:31 PM
Whitedog's Avatar
I believe so. The ignition will spike, and send more than 12v to the tach.
Old Apr 6, 2006 | 11:47 PM
16polaris's Avatar
What is the best way to solve my problem?
Old Apr 10, 2006 | 01:56 PM
badazz400's Avatar
get a battery eliminator kit or put your battery back on
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
wannabe32
Jul 7, 2015 11:30 AM
wildbill59
Jun 9, 2015 02:28 AM
Jbird4681
Jun 9, 2015 01:59 AM
