98 300 4x4 transmission problem
Old Apr 3, 2006 | 06:25 PM
Destructo's Avatar
Default 98 300 4x4 transmission problem
I just rebuilt the motor on my 98 fourtrax 300 and replaced the connecting rod and everything. The problem i'm having is that when the neutral light is on I am in first gear, and I can shift down into reverse but you have to rock the quad a bit to make it go in. It won't shift up past first either, the shifter moves up like normal, but it doesn't pop into the next gear. I'm trying to figure out if this is a shift linkage problem, or a shifting drum and fork problem.
Old Apr 5, 2006 | 12:44 AM
1988TRX250R's Avatar
Sounds like you put something together wrong in the tranny. Did you try shifing thru the gears before you put the cases together and again right after you tightened the case bolts? You can try removing the shift mechanism and trying to shift the tranny. If that doesn't work, you're going to have to split the cases.
greg74
Sep 10, 2019 03:03 PM
Captjay
Jul 23, 2015 12:33 PM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
bikedad3
Jul 2, 2015 02:15 AM
