Yfz 450 shocks on Rpaotr 660r
Old Apr 4, 2006 | 10:26 PM
Belleye's Avatar
Default Yfz 450 shocks on Rpaotr 660r
I have a 2005 raptor 660r, and i heard that you can put the yfz 450 shocks onto it.
How much modifications do i need to make to make this work and how much is a pair of the shocks.
Old Apr 4, 2006 | 10:31 PM
velocyraptor's Avatar
you need to grind off the a-arms and a pair on ebay goes away for about $250
Old Apr 5, 2006 | 09:10 AM
heatseeker8's Avatar
Not true at all...first you do not need to grind anything..set your preload to nearly zero and instal like that..it may take a long and thin pry bar to compress the shock a little to get the top bolt through.
Old Apr 5, 2006 | 09:46 AM
JohnyRocket's Avatar
Advantages over stock 660R shocks? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 5, 2006 | 07:23 PM
Topdollr's Avatar
I have them on my rappy. You need to do the grinding like vel said. The round top shock mount on the frame needs squared and the bottem mount on the a arm needs part of the U shaped mount ground off. Once you get the shocks you will see what needs done. I got lucky and picked up my 05 450 LE shocks for $150. They were new take offs.
Old Apr 15, 2006 | 04:05 AM
caliraptor's Avatar
Obviously you dont have a 660 with yfz shocks. Velocrapy is right, you need to do some grinding. I just installed a pair of yfz shocks on my 03 660 and had to grind on the top shock mount, lower control arm and a bit off the shocks.
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
