1999 Praire 300
Usually loose belt will cause the squealing noise when taking off.
What is your belt deflection measurement after you put a new belt?
It should be within 25 to 30 mm with 13 lbf.
Remove a shim or two in the driven converter bushing to increase the effective diameter of the sheaves so that the belt comes tighter. Get it near to the minimum spec if possible. If it is too tight, quad may creep when idling in gear.
Steeldon
Sep 9, 2015 09:38 AM
GirlsCan2
Technical and How-To Articles
Aug 27, 2015 02:58 PM
