04 Grizzly
Old Apr 8, 2006 | 08:43 PM
WEEKEND's Avatar
Default 04 Grizzly
Hey Guys
I Bought an 04 Grizzly about 2 weeks ago, at the time everything seemed to be fine. The first time out i got in water a little deeper than i thought. I somehow got water in the oil, after 7 oil changes finally no water. But now machine is smoking when I give it gas. Any ideas what could cause this? The machine only has 270 miles on it.
Old Apr 8, 2006 | 08:48 PM
Kharper450's Avatar
Default 04 Grizzly
We had a KFX700 do this. Once we changed the oil and filter on it. The smoking stopped.
Hope this helps.
Kevin
Old Apr 8, 2006 | 10:30 PM
WEEKEND's Avatar
Default 04 Grizzly
It took 7 oil changes to get all the water out. That has already been done, it is still smoking.
Old Apr 9, 2006 | 12:21 AM
squeege's Avatar
Default 04 Grizzly
You can't hurt it to ride it. It has oil in the top end....It will eventually burn off.....if you burn 1/2 tank or more...if not then you may need new rings, but a fat chance of that
Old Apr 9, 2006 | 12:58 AM
Kharper450's Avatar
Default 04 Grizzly
How did water get into the oil in the first place?
Just seen that you didnt know... Check for leaks maybe? Could have a leak on a seal or somthing donno if that would cause it to smoke or not?
Old Apr 9, 2006 | 10:45 AM
WEEKEND's Avatar
Default 04 Grizzly
Really not sure how water got there, the only thing i can find is thru crank case vent that runs to air box, I didn't think I was quite that deep but I dont see any other entry point. Any other ways for water entry?
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
rawbdiggity
Sep 7, 2015 12:05 PM
