carb problem
Old Apr 10, 2006 | 07:11 PM
lastinline's Avatar
Default carb problem
Here is my problem, when i climb a steep hill or pull a wheely i get a dead spot in the middle and top end, if i take the carb off and clean it , then its fine till i do a steep hill climb or a wheely again, ive tried every adjustment posible,what would cause this? its a 99 300ex, your input would be greatly appreciated THANKS.
Old Apr 10, 2006 | 11:36 PM
bal3wolf's Avatar
so you have played with the fuel mix screw under the carb.
Old Apr 11, 2006 | 12:05 AM
lastinline's Avatar
yes.
Old Apr 11, 2006 | 12:35 AM
fixitman69's Avatar
Sounds like your float in your carb might be set too high so it will flood out whenever you get on a steep incline.
Old Apr 11, 2006 | 11:40 AM
lastinline's Avatar
i didn,t see a way to adjust the float, its all plastic with just the pin and valve, how do you adjust it? thanks
Old Apr 11, 2006 | 12:05 PM
bal3wolf's Avatar
tat pin inside of the plasic has washers and a clip on should be set on 3 or 4 for most locations remmber not to lose the washers and were each was.
Old Apr 11, 2006 | 12:35 PM
lastinline's Avatar
i'll check that out. THANKS
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
