changing clutch weights on the HO
Old Nov 17, 2000 | 02:37 AM
silverado's Avatar
how hard is it to change the clutch weights on the HO? i want to go to the 44's.?
Old Nov 17, 2000 | 11:47 AM
silverado's Avatar
do i have to replace the seal oround the belt housing after i pull it off?? thanks
Old Nov 17, 2000 | 01:42 PM
fourlix's Avatar
This is really not hard. I don't think you have to dismantle the clutch to change weights like you do when you change springs. One time saver is to take the 4 bolts out of the floorboards at the footpegs, but leave the floorboard attached to the fenders. It will flex/swing out of the way when you pull off the clutch cover. I would think a little sealer on the clutch cover would be a good idea if you're
into lots of mud and water. Maybe just on one side, let it dry before putting it back together so it isn't a mess the next time you take it off.
I can change a clutch spring in less than 30 minutes.
I still have my stock 46 gram weights on my H.O. but I put a white spring in. It works great,
only clunks once, when it's cold. Let us know how the 44's work. They should give you a little more rpm, therefore a little more power.
If you tell your dealer you ride at high elevation he should change these weights for you for free. Buy a white spring and have them stick it in for you while it's apart. Tell them it's running "doggy" up there in them thar hills.
Silly Later,,,,Fourlix
Old Nov 17, 2000 | 02:36 PM
silverado's Avatar
hey fourlix what did the white spring do for ya,i creep around in the woods alot so i dont want it to engage anyhigher than it does.how did it effect your HO?
RedRancher
Oct 15, 2020 01:45 PM
Cummins Driver
Sep 11, 2019 01:22 PM
cornermike
Aug 10, 2016 06:47 AM
panicmanic
Aug 11, 2015 06:50 AM
Ashley S
Jul 30, 2015 08:38 AM
