PLUNGER AND SPRING QUESTION ON 400EX HEAD
Old Apr 13, 2006 | 01:33 AM
saint650's Avatar
Default PLUNGER AND SPRING QUESTION ON 400EX HEAD
I AM REBUILDING A FREINDS 400EX. I HAVE BUILT MANY QUADS AND SNOWMOBILES BUT NEVER A 400EX BEFOR. I AM INSTALLING A 10:1 PISTON .80 OVER AND A STAGE 1 HOT CAM. GETTING THE MOTOR BACK TOGEATHER AND I WAS READING THE CLYMERS MANUAL AND SAW A SPOT ABOUT A SMALL SPRING AND PLUNGER UNDER THE CAM. I CHECKED THE HEAD AND THE SPRING IS THERE BUT THE PLUNGER IS NOT. I CALLED THE MACHINE SHOP TO SEE IF THEY HAD ONE AND THE SAID THEY DID NOT LOOK FOR IT BEFOR THEY DISASSEMBLED THE HEAD BUT THEY ARE A HONDA DEALER AND SAID THEY CAN NOT COME UP WITH A PART NUMBER. ANY ONE HAVE A PART NUMBER OR KNOW WHERE TO GET ONE? I NEED TO GET THIS RESOLVED ASAP. THANKS FOR ANY HELP.
Old Apr 14, 2006 | 12:48 AM
dunefool's Avatar
With most aftermarket cams you get rid of these items.
Old Apr 14, 2006 | 03:31 AM
cals400ex's Avatar
if you are running a hotcam, you will want to remove the spring and plunger anyways. if you look at your hotcam and your stock cam side by side you will see this extra material by the cam flange on the stock cam. this will not be there on the hot cam. all of this is the decompression assembly. the hotcam does not use this so you will want to remove the spring and plunger anyways.
just so you know, here are the honda part numbers:
spring: 14126-KV2-940
plunger: 14125-KV2-940
Old Apr 14, 2006 | 02:39 PM
saint650's Avatar
thanks for the info. its funny they never mentioned that in any of the hot cams paper work. i pulled the spring and put it togeather.
Reactant
Mar 30, 2022 02:08 AM
95wolv
Jul 21, 2015 12:25 PM
Wnthunting
Jul 9, 2015 03:02 PM
yambam13
Jul 4, 2015 01:49 PM
Mphillips
Jul 2, 2015 07:20 PM
