Wheelie Shifting
Old Apr 24, 2006 | 07:18 PM
bumrushfromhell's Avatar
Default Wheelie Shifting
Anyone have pointers on how to shift up through the gears while keepon ur wheelie goin. As soon as i pull the clutch in it drops so by the time im in to 3rd my fronts hit back down. If anyone can give me some pointers that would be awsome!
P.S
To anyone who thinks u cant wheelie shift, ive seen it done so i no its possible!
Old Apr 24, 2006 | 07:21 PM
mykool61679's Avatar
power shift, without the clutch
Old Apr 24, 2006 | 08:45 PM
slomoe's Avatar
I quit wheelie shifting after i looped out on pavement if i want 4th i pull the wheelie in 4th gear
Old Apr 24, 2006 | 08:49 PM
mack63's Avatar
If your front end drops at third gear then I would say you have not found the balance point of the machine. If your wheelie is at the ideal balance point then you should have plenty of time to use the clutch to shift. I would recomend doing slow speed wheelies in 1st gear and get a feel for how high you can go before your on the grab bar. Practice using the throtle and rear brake and once you master that you'll be riding wheelies through all the gears.
Old Apr 25, 2006 | 01:41 AM
trav300ex's Avatar
Yep good info right there.
Also, once you find your balance point, and are ready to shift, get a little back on the balance point so the drop doesn't fall.
Old Apr 25, 2006 | 06:17 PM
Atvstevo1337's Avatar
you definately gotta find the balance point first, With my blaster I pull it up in 4th and shift to 6th unless im in my yard ill pulll it up in 2en, make sure your in the powerband area of the RPMs
Old Apr 25, 2006 | 10:36 PM
honda4life06's Avatar
shift without the clutch it is the easiest way
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
