LT 80 info / help
Just bought an well used 87 id like to know what breaks on these, what matenace needs done to them / what i parts i should check foe wear , and posibly what upgrades / modifications to make
first of this isn't going to be raced (maybe after he gets a little time on it he can go to the local track) for know it will be a trailrider please keep this in mind when sugesting up grades
i have till july (my son's birthday) to get this back up running and looking like good. it starts and runs good blows a little smoke i asume this is normal of a 2 stroke. I've never had a cvt eather should it feel like one long gear and go about 20 mph with the engine reve'd up
i could you guys allso recomed some places to get parts
so far my parts list goes
-rear fender (yellow used would be great)
-new batery
-front and rear wheel bearing
-oil and air filters(of course)
-new front tires posibly new rears
-front brake cables(im going to try and get the ones i have broke free)
-new batery
I getting ready to run out the door, so I'll shoot from the hip really quick. Might miss a couple things I'm sure.
But if you do a search on here for LT80 you will find a lot of info, you'll read a lot, but worth it.
Go ahead and change the oil. It only takes about 80cc of oil. You can find info on where/how.
Pull front clutch off, clean and regrease. Take 2 rollers out.
Pull carb and clean. Re-jet to either a 87.5 or 90 main jet. Try needle clip in #1 or #2 position.
Get a Uni air filter
New plug
DC the oil injection, run 32:1 premix
Grease the front end and rear axle housing
Check the brakes
If you want to widen it out to make it more stable, there are a few options.
Anywhere from under $10 to $150 or so. You'll find plenty of info on here.
good Luck, goota run
New plug
Check the brakes
i started tearing it down last night difnatly need new front brake lines front bearings look good im just going to clean them out and repack them. is there some place were i can see some pictures of the clutchs. maybe a tear down. im not scaried to work on my owen stuff but i never really worked on quads.
well it closer to 25 mph with my big azz 300 lbs+ on it
greg86hd
Sep 16, 2015 12:32 AM
