what services should be due
Old May 2, 2006 | 01:12 PM
airforcedad's Avatar
Default what services should be due
hi i have a 2002 220 bayou that gets reg oil changes and lube its used about 60 hours per year
services should i be doing as far as clutches transmission brakes etc any suggestions as to what might be going soon and be service preventively
thanks
Old May 2, 2006 | 03:36 PM
sandpit's Avatar
Check air filter,and maybe change the rear end fluid.
Old May 2, 2006 | 04:01 PM
Hayashi's Avatar
The weakest design/part on your 220 is the "plastic" gear of the oil pump. If that white plastic gear fails, your engine would be a total waste from top to bottom. If you operate (read "shift") the quad properly, this would not happen. However, some folks just ride in a high gear for all speeds even when the quad is barely cralwling - too lazy to shift down. This causes excessive heat from slipping clutches, and to make it worse, there is not enough engine rpm for the oil pump to pump oil to lubricate and cool down the hot engine parts. The plastic can't withstand the heat too long and they melts and breaks (heated plastic becomes brittle when it cools down due to quenching effect) - the end of poor air cooled engine. Proper shifting is very important on Bayous, otherwise they are bulletproof. If you are in a doubt, check the teeth of the plastic oil pump gear for any sign of wear or heat damage. If I were you, I would fabricate a steel gear and replace the plastic one. Other maintenance items are just like on any other quads - no special attention needed.
Customer Service #1
May 15, 2020 08:46 AM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Elkaholic
Sep 6, 2015 02:44 PM
