EX has loose clutch problem
Old May 6, 2006 | 12:48 AM
ubertrailblazer01's Avatar
Default EX has loose clutch problem
heres where it all (possibly) started:
sometime back in december or so, i was riding around in the snow. i whipped in into a snowbank, and bogged out. restarted it, and attempted to put it in first gear, but the clutch would pull all the way in and not engage. i manged to ride it home by starting it in neutral and riding home in first (without the clutch, but i didnt rev it up or anything). ordered a new clutch cable, put it in a week later. then later (march or so), it was getting loose, so i unscrewed the adjuster so theres about 3 threads in, this held off for a while. but now recently its been getting loose again, as i can pull the clutch in almost halfway before it starts to engage, and letting it out the slightest amount (from a full grab) and the quad starts to move. also, pulling it in all the way at a standstill, it is hard to get it into neutral. im for sure taking it into the shop unless anyone has an idea what to do. thanks
Old May 6, 2006 | 04:36 AM
IdahoVinnie's Avatar
With a new clutch cable, and it's nearly to the end of it's adjuctment, then you probably need a new clutch assembly.
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
