300ft. Race Mod times?
Old May 7, 2006 | 08:26 PM
16polaris's Avatar
Default 300ft. Race Mod times?
Well after alot of trial and error on clutch tuning and trying different pipes, I finally got my race mod down to where it needs to be. I ran a best time of 5.14 lastnight in 300ft. What times are everyone else running on race gas? Or on alky?
Thanks!
Old May 8, 2006 | 12:02 AM
Whitedog's Avatar
Thats great Nathan. Glad to see you finally gotit right! So what clutch and gear setup did you wind up going with?
Hell, the best I ran last year was a 4.92 on alky. I wont know what it runs with my new pipe and clutches until later this summer. our closest timed track is 5 hrs away.
I did get 1st place yesterday at our local heads up race tho. =D
Old May 8, 2006 | 12:11 AM
16polaris's Avatar
Thats good, I always LOVE to hear about a Polaris being in the winners circle! I ended up with 10-56 weights, Almond/blue primary, and stock gearing, do you think I would gain anything if I put th 30 tooth rear sprocket back on? My 60foot times were 1.8 something i'm not really sure.
Old May 8, 2006 | 12:47 AM
Whitedog's Avatar
Man, I duno what to tell ya about the gearing. Your 12-34 now? Im at 13-30 right now. You oughta try the 30 one night and let us know what the difference is. It seems like these quads like the low gearing. I used to do real well with 14-36 but since I put the new stuff on, and lost some more weight, I thought I might be able to go higher.
Old May 8, 2006 | 12:49 AM
16polaris's Avatar
Yep im at 12-34 right now, I think I will put the 30 on and try it, I also think if I put a Almond/black primary in to get the stall above 4000 I think it will help me some too.
Old May 8, 2006 | 01:03 AM
Whitedog's Avatar
I just did the math. I gota bet that youll go faster with some higher gearing. Unless its real soft and ur real big guy.
TTYL
Old May 8, 2006 | 01:17 AM
16polaris's Avatar
The track is a dirt/sand mix, it can be dry or it can be a little wet from time to time, I weigh 175lbs. So what do you think?
Old May 8, 2006 | 01:30 AM
16polaris's Avatar
I also forgot to mention that I was dialed in at a 5.15 but when I ran the 5.14 I let off the throttle about 20 feet before I crossed the finish line, so i'm not sure what my best ET would have been, maybe 5.10? But I still broke out.
Old May 8, 2006 | 03:52 AM
jimmypsp700's Avatar
Awesome man, thats FAST.... keep up the good work!
Jim
Old May 8, 2006 | 12:42 PM
POLARISFREAK's Avatar
Thanks!
Are you running paddles or prowedges?
