400ex problem
Old May 8, 2006 | 09:10 PM
crazy400exrider's Avatar
Default 400ex problem
my 400ex wont shift....what could possibly be the problem here...any help would be great...thanks
Old May 9, 2006 | 12:01 AM
ROTTY261's Avatar
Have you checked with your local dealer to see if your quad was effected by the recall that came out a couple of months ago? It was a recall on some parts in the tranny effecting 1st gear and reverse..
Old May 9, 2006 | 12:28 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
What years is it?
Old May 9, 2006 | 04:23 PM
its a 2004...i bought it brand new last june
Old May 9, 2006 | 05:07 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Hmmm, no recall on the '04s. Is there oil in it? What do you mean it ain't shifting, is it stuck in gear, stuck in nuetral?
Old May 9, 2006 | 07:04 PM
some times if i keep pumping the shifter it will shift but other than that it wont shift...its not stuck in any gear
Old May 10, 2006 | 07:14 PM
has anyone ever heard of this happening to a 4-wheeler?
Old May 10, 2006 | 08:50 PM
quad2xtreme's Avatar
could be the shift fork inside the tranny. Not all that common on a 400ex but it does happen.
Make sure your shifter isn't bent though and rubbing the case.
/Jon
Old May 11, 2006 | 05:35 PM
RancherATCrazy's Avatar
Does it have an angle sensor on it? I had the same problem with my Rancher it is an automatic but it ended up that there was nothing wrong with the tranny at all it was the angle sensor.
Old May 11, 2006 | 05:52 PM
DaBeechMan's Avatar
bent shift forks are real common on the 400's. most likely you have a bent shift fork
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
