250 Dingo HELLPPPPP!
Old May 10, 2006 | 01:31 PM
family's Avatar
Default 250 Dingo HELLPPPPP!
I have a 250 dingo that will not start. Battery is charged the safety feature is ok. When you try to start it all it does is click? Could this be the starter? Thanks
Old May 10, 2006 | 02:19 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum family, It could be the starter. Does the battery have a full charge? At 11 volts the headlight would work, but it might not be strong enough to turn the engine over.
Old May 10, 2006 | 02:40 PM
billl2099's Avatar
first make sure you're battery is in good condition and has a good charge to it, second take a wire and jump a cross the starter solenoid, if its starts then thats the problem, if it doesn't and still clicks next would be to remove the starter and test it hook up electrical and see if if it works, if it does then it might be internal engine damage. THE VERY FIRST THING TO DO IS TAKE A WIRE BRUSH AND CLEAN THE BATTERY CONNECTIONS ON THE BATTERY, THESE CONNECTION CORRODE REALLY BAD
Old May 10, 2006 | 03:49 PM
family's Avatar
I will try that thanks so much for the help guys.
Old May 10, 2006 | 04:50 PM
squeege's Avatar
9x out of 10 the connections are loose
Reelgator
Feb 12, 2019 04:41 PM
DrFfreeze
Apr 28, 2007 03:06 PM
DrFfreeze
Mar 26, 2007 11:16 AM
Cmarti
Apr 12, 2006 11:26 PM
Prezzz
Aug 22, 2005 06:15 PM
