Sportsman Carb vs. Predator Carb
Old May 17, 2006 | 08:42 PM
MaineMudder3's Avatar
Default Sportsman Carb vs. Predator Carb
I've searched on here for 2 nights without any luck. Have a 2003 sportsman 500ho with many mods, diff piston..cam..have the Mikuni 40mm CV carb on it like all the Sportsman HO's did. Been doing some research and noticed the Predator has a 42mm BSR carb. My question is would it be possible to put the Preddy carb on the sportsman 500? The only little niche that I read somewheres is the Preddy has a special fuel pump to supply the 42mm carb, does this sound correct? I'd really like to try it because what I really want to do is run mine with no airbox as I'm converting it over to a competition pull bike. Can't run the stock 40mm HO carb without an airbox because it needs the constant vaccum from the airbox but I know you can run a preddy without an airbox which is what I want! If anyone knows please let me know asap! Thank!!
Old May 18, 2006 | 10:37 AM
Speedwerx's Avatar
We havn't done it but I'm sure it can be done. A stock predator can run without the fuel pump too I don't suggest it but it will work. You most likley should expect to have some jetting fun too if you decide to go with the predator carb, if do decide to try this and you need a pred. stk carb let me knwo I have a couple laying around.
Old May 18, 2006 | 07:29 PM
How much would you sell me one for? I can get one at a decent price locally right now..PM me a price and shipping please!
Old May 18, 2006 | 10:39 PM
yammaslamma's Avatar
preddy carbs can be gravity fed i believe...
Old May 19, 2006 | 10:25 AM
Speedwerx's Avatar
100.00 for the carb plus shipping. Ups ground should be about 9.00
Old May 19, 2006 | 09:06 PM
I am correct in saying though that a predator CAN be run without an airbox correct?
Old May 22, 2006 | 10:49 AM
Speedwerx's Avatar
yes once jetted properly.
Old May 22, 2006 | 10:50 PM
Can my stock 40mm be run without the airbox? If properly jetted?
Old May 23, 2006 | 10:23 AM
Speedwerx's Avatar
Yes, Once jetted properly it should work.
Old Jun 16, 2006 | 11:10 PM
SPORTSMAN70003's Avatar
MM did you ever try the predator carb?
Ipmcelroy
Technical and How-To Articles
48
Nov 21, 2015 08:02 AM
coldnorthpol
Jul 14, 2015 11:22 PM
tweeder
Jul 5, 2015 01:57 PM
JBibb
Jul 4, 2015 10:16 AM
Jul 1, 2015 12:45 AM
