Bayou 250 starter problem
Old May 21, 2006 | 10:27 PM
tencubed's Avatar
Being retired is a hoot!
Default Bayou 250 starter problem
My daughter-in-law called and told me the starter on our Bayou 250 started making a grinding noise and quit turning the engine over. Haven't seen the machine yet but wanted to know if this is a common fault or if anyone had suggestions that may be helpful.
Quad starts and runs fine using the pull start and the battery is fully charged.
Old May 22, 2006 | 12:53 AM
Slinger's Avatar
Do you know how to test the starter? I had a problem with mine and its ground. Then I had a problem with the brushes inside wearing out and causing a grinding noise similar to what you describe. After I fixed that, I had a problem with one of the magnets detaching from the inside of the starter and sticking to the field. This caused the starter not to work/turn at all. All of these problems were quite fixable when compared to the price of a new one, and I performed all the work myself. I've had this Bayou since '95 and these three starter problems are all that have surfaced.
Old May 22, 2006 | 12:56 AM
Slinger's Avatar
I just realized something. Is she sure its grinding or is it possible that the battery has become discharged and its the solenoid she hears. It will sound like a rapid clicking and may seem like grinding.
Old May 22, 2006 | 01:36 AM
tencubed's Avatar
Thanks for the responses. It will be a couple of days before I am where the quad is but I'm glad to hear of your experiances. Sounds like there are a few things that may be causing the problem. The battery is fully charged.
tweeder
Jul 5, 2015 01:57 PM
rcappie4
Jun 21, 2015 07:33 PM
jgreerberube
Jun 21, 2015 02:27 PM
momofo
May 27, 2015 12:06 PM
C.bailey
May 26, 2015 09:01 AM
