Air box lid off with o6 hrc install
Old May 25, 2006 | 11:58 PM
HickBoy's Avatar
Default Air box lid off with o6 hrc install
I just had my 06 trx450 hrc kit installed. The dealer took the airbox lid off. Is this required for the o6 hrc kit? Should I be concerned about dust/water getting in my airbox? Also should I get a sparks slip on muffler or just leave the stock one alone.
Old May 26, 2006 | 02:25 AM
dunefool's Avatar
You should have gotten the manual that comes with the HRC kit, it will answer all your questions. You will need to clean your air filter much more often.
Old May 26, 2006 | 09:44 AM
quad2xtreme's Avatar
Yes it is. You can add an EHS Racing lid though that definitely helps. checkout www.ehsracing.com. You must order the complete lid setup for a 2006 450r...other quads have D-I-Y kits.
/Jon
Old May 26, 2006 | 10:13 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Highly recomend the EHS Racing lid!!!
The stock muffler performs pretty well, once it is uncorked. But, it is heavy like a brick! An aftermarket one will be pounds lighter........
Old May 26, 2006 | 10:53 AM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
Instead of taking the lid completely off I cut mine out to look like the 04-05's. I then took an old pair of pantie hose and streach over the lid which covers the hole. It works great and catches the big stuff.
Go to 450.org and do a search on the homemade HRC lid.
Old May 26, 2006 | 03:56 PM
HickBoy's Avatar
Thanks for the info. Would a K and n filter with outerwear cover do the job?
Old May 26, 2006 | 06:05 PM
Maybe but you are speaking religion...personally, I fall into the "foam only" camp.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
