Fan running constantly
Old May 29, 2006 | 11:16 PM
crashby's Avatar
Default Please Help!!!
Well i rode my 400 all weekend and now the fan wont shut off and it constantly says "HOT, CHECK ENGINE". The fan runs with the key OFF and it just runs till the battery dies. I was thinking a bad sensor?? Pease help!!
Old May 30, 2006 | 01:01 AM
scrammersam's Avatar
the sensor would be a good place to start. its highly unlikely its that hot. unless the coolent is not cycling at all.
Old May 30, 2006 | 01:46 AM
Polaris500HO4x4's Avatar
more then likely your sensor... i do know the polaris 500 efi models had a similar problem
Old May 30, 2006 | 07:32 AM
rsking45's Avatar
My 500ho was doing the same thing and the ecm was replaced problem solved
Old May 30, 2006 | 03:08 PM
crashby's Avatar
The bike will sit for a day and as soon as you turn the key on it flashes "HOT". Where is the sensor located and how much does it cost?
Old May 30, 2006 | 09:37 PM
rsking45's Avatar
Polaris had a recall last year on certian sportsman models because of defective ECMs.Do a search to find out if yours was one on the recall list.if so the dealer should replace for nothing.
Old May 30, 2006 | 11:54 PM
crashby's Avatar
Well i unplugged the fan but the speedo still flashes "HOT"
Old May 30, 2006 | 11:59 PM
Default Fan running constantly
unplugging the fan wouldnt fix it. your ecm must be out, im thinking a bad sensor would cause fan to run constantly. but the hotlamp sensor is a different sensor i believe. so both of them would have to be out.. right?
Old May 31, 2006 | 12:02 AM
ricknzep's Avatar
There is a recall on bad ECM's, check with the dealer. www.consumeraffairs.com lists the recall for 04 and 05 400's, 500's etc.
Old Jun 1, 2006 | 05:01 PM
crashby's Avatar
This may be a stupid question, but what exactly is the ECM????
