Increase YFZ Top Speed
Old May 31, 2006 | 03:47 PM
SpeedDemon13's Avatar
Default Increase YFZ Top Speed
The YFZ top speed is not near as high as I would like it. I heard that it hits the rev limiter stock so when you mod it, it does not get any faster on top speed. I am going to get a Curtis Sparks exhaust with the big core, jets, and k&n. I want to be able to keep up with the raptors on top speed. It sounds like its gonna blow up when I start getting toward the top speed but I am not even close to keeping up with the raptors so I dunno.
Old May 31, 2006 | 06:03 PM
warriorryder's Avatar
just change the gearing...go up on the front sprocket or go down on the back...or do both
Old May 31, 2006 | 08:13 PM
DSNUT's Avatar
I would keep stock gearing and buy a set of 22" medium buff extreme haulers with 8 paddles. They need to be on 8" diameter wheels. You will pick up good top speed and you will pick up a couple lengths when you race.
Old Jun 3, 2006 | 08:07 AM
0u812's Avatar
Go up one tooth in the front .
Old Jun 3, 2006 | 08:18 AM
Scooter86's Avatar
Knows Old ATV Questions!
The YFZ can pull taller gearing, if it is top end you want, just gear it up, either with a sprocket change or larger tires. Going up in tire size may add weight though, and will be more expensive. Changing out a sprocket is cheaper and you may even lose some weight over stock.
Pehter
Oct 3, 2024 11:00 PM
2many2ride
Sep 27, 2015 04:35 AM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
