Slime in tires?
Old Jun 3, 2006 | 10:41 AM
WinterRules's Avatar
Default Slime in tires?
Does anybody use slime in their tires ? How well does it work?
http://www.slimesealant.com/product.php?product=blue
Old Jun 3, 2006 | 11:28 AM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
Yes, I have it in my atv tires. It says to use a whole bottle per tire, but I used 1 bottle for two 27" tires. You put it in and drive it around a while and it seals everything up. It stopped my slow leaks on my gators.
Old Jun 3, 2006 | 10:48 PM
alisonsandmindysdad's Avatar
I wouldn't go anywhere without it. I have used the HD slime (black rubber chunks in it) for several years. I used to live in Nebraska and Utah where there is a ton of cactus. Never have any flats with slime. You are supposed to take width X height X .12 to determine the number of ounces to use. Walmart has gallons with a pump for $28.??. A gallon should do most atvs with some left over. I've used other brands but have settled on HD slime.
Old Jun 5, 2006 | 12:12 AM
XxBamBam2xX's Avatar
i have it and love it the first time i went riding with it in them i got a big thorn in one of my tires and just pulled it out and the slime seals it right up i would never go anywhere without slime in my tires
Old Jun 5, 2006 | 07:13 AM
SG1's Avatar
SG1
I bought my kingquad used and they had slime in the back tires. When I took the old back tires off of the rim the slime was just that slime it was very nasty and after seeing what it looks like inside of a tire and it didn't help that tire because it was still going flat very fast so I would not recommend slime or anything like it. I would just make sure the tires are aired up before you leave camp. You can buy many types of air compressors actually you can even buy a 12V air compressor that will plug in your 12V plug on your atv and air your tire up while on the trail. That's just my opinion on this. But after I bought my ITP mudlites I didn't have a problem with flats.
Old Jun 5, 2006 | 03:37 PM
kfxandahemi's Avatar
I have slime in my tires as well. Living in wyoming you wont get home without it due to the cactus here. It works well, just a little messy if you change the tires and such. They will still go flat if you stick something big in your tire, but for cactus, thorns, ect.. it works well.
Old Jun 5, 2006 | 03:47 PM
fastrthnu's Avatar
I had slime in my old tires and man it works awsome, but when i changed my tires it was really messy.
Old Jun 5, 2006 | 04:02 PM
You can rinse it off with a garden hose. They are all messy when you change tires, but beats flat tires.
Old Jun 5, 2006 | 05:06 PM
fastrthnu's Avatar
That's very true.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
