HELP.....I wanna ride!
Old Jun 5, 2006 | 06:51 PM
rickyk1's Avatar
Default HELP.....I wanna ride!
I am trying to get my 99 trx 250 recon running again! I have power off of my stator and pulse pick up but no spark....so i know it is either my cdi or my rectifier regulator...(i know that the coil is still good)......does anyone have a clue on how to test these two pieces and what the specs should be on them.....any help would be greatly appreciated!!
Ricky
Old Jun 5, 2006 | 09:19 PM
White7's Avatar
Invest in a service manual,and you'll be ridin in no time
Old Jun 5, 2006 | 11:29 PM
motoxshane's Avatar
try a simple $2 spark plug, if thats not the problem then trace the wires from the stator or rectifier to the coil and unplug those wires stick a voltmeter in each wire while cranking the engine if you get a valid reading than the parts good otherwise it needs replaced or first make sure it has a good connection/ ground
Old Jun 6, 2006 | 02:14 PM
hondabuster's Avatar
Id suspect the spark plug or the kill switch first. Those cdi s dont go bad very easily.
Old Jun 6, 2006 | 11:35 PM
rickyk1's Avatar
I Know that it isnt the spark plug i can grab the wire from the coil there is nothing coming out but i know that the coil is good cause i put it on my bayou and it worked fine...............
Nondem
Feb 22, 2020 12:20 PM
HondaR24
Jul 16, 2015 10:45 AM
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
