Help...Ive got troubles!!
Old Jun 7, 2006 | 11:07 AM
Fireshadow's Avatar
Default Help...Ive got troubles!!
I have a 2000 Rancher and my ES has completely stopped working.I have already replaced the angle sensor but I still have nothing.Ive resorted to taking off the plastic so I can use the manual shifter like a normal shifter any suggestions are welcome...other wise its gonna be 2-3 hundred at the honda shop.....
Old Jun 7, 2006 | 10:49 PM
quicksilver's Avatar
ok, so the ES has completely stopped working, no noise or anything when you try to shift? Is there any codes that come up?
I would think that maybe your shift motor is bad, or you have bad wiring, etc. Maybe the shift switches went bad? Check the fuses? Try to narrow it down for us
good luck
Old Jun 9, 2006 | 12:29 AM
Fireshadow's Avatar
Thanks for answering, a little more detail, my es switches are not making any sounds, no codes or any respones.I checked the fuses under the seat and they were all good. I called the honda dealer an they told me to check the nuetral and reverse lights and I have both of them......so if you can think of anything else....it will greatly be appreciated...
Old Jun 9, 2006 | 12:41 AM
well if theres no noise at all, i would think you maybe have a bad shift motor. Unplug the shift motor with the key off, and hook up a 12v test light across the plug coming from the wire harness, so that the test light is plugged in in place of the shift motor. turn the key on and try to shift gears. If the light lights up, in both up and down shift, then you probably have a bad shift motor. If it still doesnt work, maybe buy a manual and start checking for power at the ECM connectors that have power with the key on. Also check the ground circuits too.
Old Jun 9, 2006 | 01:30 AM
Fireshadow's Avatar
Ok,I ll check the shift motor,just to make sure the location of the shift motor,is it the round cylinder that come off the front of the engine or is it in another location.Just before it went out, on my last ride when I would first start moving it would go from 1-4 just fine but once I stopped shifting it wouldnt shift into 5 and it wouldnt down shift I would have to turn it off....but like I said now nothing..
Old Jul 20, 2006 | 03:24 AM
LOANSHARK's Avatar
Fireshadow, did you ever figure this out?
Old Jul 23, 2006 | 04:13 PM
Fireshadow's Avatar
I did figure it out,turns out it was a simple fix,the power supply plug under the fuse box under the seat was loose.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
