Recon back fireing
Old Jun 8, 2006 | 07:54 AM
RABDAB's Avatar
Default Recon back fireing
We put a K&N air filter in my sons 02 Recon now it back fires when he lets off the gas with the engine compression. We were told it was to lean and moved the needle but it did not make a difference. Any sugestions. Thanks PS. it did give it a lot more power
Old Jun 8, 2006 | 01:47 PM
hondabuster's Avatar
Youre right to think its from being too lean. But on throttle letoff, the carb is running on the idle circuit, not the needle, so turn the mixture screw out 1/4 turn or so, and that will richen the idle circuit only.
Old Jun 9, 2006 | 12:03 PM
RABDAB's Avatar
Thanx you. i was looking at the service book and did not find a mixture screw on the carb. perhaps it was called somthing else.
There was a
Throttle Stop screw. I think that is the idle adjustment.
Pilot screw
and a drain screw.
I think it is the pilot screw.
Let me know.. thanxs again
Old Jun 9, 2006 | 12:52 PM
Its the one on the underside of the carb. Just forward of the float bowl. Screwing out, is richer.
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
