removing carb on warrior
Old Jun 8, 2006 | 02:17 PM
98warriortaz's Avatar
Default removing carb on warrior
I'm removing the carb on my 98 warrior so a friend can rebuild for me. I can easily see how to get off the fuel and air hookups, but I need help in how to remove the throttle linkage. I don't want to screw up the throttle cable. Any help would be appreciated.
Thanks
Old Jun 8, 2006 | 02:39 PM
AustinONeal's Avatar
take the black cover off the side and remove the throttle cable from the arm then pull it through, u also will have to screw the cable off the housing
Old Jun 8, 2006 | 03:48 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
take the 6 screws off...
push the thing with the cable toward where the cable came int othe carb from.. then the cable should kink(somehwhat and it should make a hill type loop... the cable then uplls out through a slit and out.. take the big part off and save it DON'T LOSE IT... then unscrew the part on the outside of the cab and pull the cable out...
Old Jun 9, 2006 | 03:27 PM
Thanks for the help. Got everything off except the blasted screw holding the cable onto the side of the carb. Its like its welded on! Plus it seems like its made of play doh, it strips way too easy.
Old Jun 9, 2006 | 04:24 PM
Speedy2222's Avatar
don't loosen the nut.. loosen the long part... if you try to loosen the small nut it is just gonig to tighten
Old Jun 11, 2006 | 10:18 PM
Got it off, thx for the help.
The folks on the forum have been great!
Jmuddin284
Jan 19, 2026 07:16 AM
Reactant
Mar 30, 2022 02:08 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
