headlight problems,,,need help
Old Jun 10, 2006 | 12:04 AM
waymore's Avatar
Default headlight problems,,,need help
i have a 2000 sportsman 500 and i'm haveing trouble with the lights going dim and flickering, after the hi beam light had blown out, the low beams done fine,,a friend of mine has had alot of trouble with this and now i am,,,someone said it could be the battery not being able to hold the load ,,,,,,,any suggestions on this subject.
Old Jun 10, 2006 | 08:36 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
first of all i want to know why the high beam had blown out. could be your recifier is crapping out. its what controlls the voltage to your charging system. if the lights are running dim aslo it could be a bad ground issue. my 2 cents
Old Jun 12, 2006 | 12:50 AM
Instigater's Avatar
Notice any problems with the 4x4 not working? On my '01,I realized the 4x4 didn't work way before the lights looked dim. Of course mine was running 5 lights, so I wasn't upset about low voltage. You should be able to check without spinning the tires. On mine, if the indicator for 4x4 came on, then it was in 4x4.
Old Jun 12, 2006 | 05:29 AM
waymore's Avatar
yeah,,,,,the awd light came on and the 4x4 works,,,,so really don't know what is wrong
Old Jun 12, 2006 | 06:37 AM
floodrunner's Avatar
My guess is you need a new voltage regulator. On that model I believe it’s mounted in front of the radiator. Before you do that it wouldn’t hurt to check the specific gravity of the fluid in each of your battery cells to see if the battery is marginal.
kodiak450.
Utility ATVs
13
Jul 27, 2015 05:07 PM
JoAnnS
Jul 23, 2015 02:18 PM
Captjay
Jul 23, 2015 12:33 PM
Derek Allen
Jul 22, 2015 09:25 PM
tweeder
Jul 5, 2015 01:57 PM
