problems with 05 450r
Old Jun 11, 2006 | 07:06 PM
chris450r's Avatar
Default problems with 05 450r
I am having problems with my 450r. It was all stock then I had the hrc kit and only installed the end cap. Ran fine and then it is having problems in the higher rpms. It is just spittering and sputtering. Well changed plugs and still did. Then I took the end cap off returened it to stock looked it over made sure no wires where disconneted and drained the gas put new in and still does it. It has no problem idiling or anything just wont go it high rpms. If anyone with some solutions would help would like to get riding again thanks
Old Jun 12, 2006 | 12:55 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
When you uncorked the exhaust, did you rejet???? If you didn't, you were running lean (lean means hot!), and may have done engine damage! Honda jets lean at the factory to meet emissions. What you did makes it even worse........
What did the plug look like? Whiteish???
Old Jun 12, 2006 | 02:38 AM
TL450R's Avatar
seems a lot like jetting. probably main jet
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
