another warrior starter problem
when i go to start it i press the button nad it makes a click that is coming from the group of wires in the back near the battery, ill press the button like 20 times nothing happens then i took the key out and in a few times and tried and it worked, the neutral light goes on and sometimes i dont do the key thing and it still works after like pressing the button 30 times. help asap
steve
steve
My Raptor was doing the same thing. I hooked up my mutimeter to the starter relay (the little component the battery leads go to) and found it to be working intermittently. Maybe you have the same problem.
I would double check all your connections first. If anything is coroded, clean it up with a little sand paper...fine grit. Also, use dielectric grease when putting things back together.
Is the battery fully charged? It's amazing what havoc a semi dead battery can cause.
