another warrior starter problem
Old Jun 13, 2006 | 05:35 PM
YamahaRider8998's Avatar
Default another warrior starter problem
when i go to start it i press the button nad it makes a click that is coming from the group of wires in the back near the battery, ill press the button like 20 times nothing happens then i took the key out and in a few times and tried and it worked, the neutral light goes on and sometimes i dont do the key thing and it still works after like pressing the button 30 times. help asap
steve
Old Jun 13, 2006 | 07:35 PM
bump
Old Jun 13, 2006 | 07:50 PM
Junior05's Avatar
My Raptor was doing the same thing. I hooked up my mutimeter to the starter relay (the little component the battery leads go to) and found it to be working intermittently. Maybe you have the same problem.
Old Jun 13, 2006 | 10:28 PM
GlennJ's Avatar
I would double check all your connections first. If anything is coroded, clean it up with a little sand paper...fine grit. Also, use dielectric grease when putting things back together.
Is the battery fully charged? It's amazing what havoc a semi dead battery can cause.
Old Jun 14, 2006 | 08:50 AM
k thanx ill check those things but i just got a new starter relay recently
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
tweeder
Jul 5, 2015 01:57 PM
