1984 TRX200 Electrical
Old Jun 18, 2006 | 10:20 PM
Joshwfl's Avatar
Default 1984 TRX200 Electrical
I picked it up today for $75 bucks for my wife to ride. It's complete minus the ignition (key) switch. What do I need to do to bypass to get it to start? It get no juice or spark.
Also, what is the rubber assembly near the light switch? It appears to be an ac or dc plug.
If these questions sound too simple it's because I ride and wrench on a CR500. No switches there. Thanks for any help!
Old Jun 18, 2006 | 10:44 PM
psvfd's Avatar
I had to bypass the switch on one of my 84 trx 200 as I had two 200's go under water in Katrina. I had spark to the plug but the switch, neutral and reverse safety switches were bad so I bypassed all of them and just have a toggle switch to turn on power to the starter switch, not good if you have someone else using the bike or kids since it will start in gear and reverse. If you do not have spark you may have to try to find the CDI and other ignition parts to get it running. I see some on ebay at times.
I toke parts from both bikes to get the one working so I do not believe I have any parts that would help you.
Good luck!
Old Jun 18, 2006 | 10:51 PM
Joshwfl's Avatar
So with the switch unplugged I should still have spark?
Old Jun 18, 2006 | 11:03 PM
2Stroke400Scrambler's Avatar
yes, if u unplug the ignition switch it will fire right up, just use ur killswitch to shut it off and leave it in gear so the neutral light isnt on, i've had to do it b4 cuz i lost the key
Old Jun 18, 2006 | 11:19 PM
Joshwfl's Avatar
Ok, thanks. Looks like I need a cdi and/or coil then right?
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
