soggy bottom, boy's
Old Jun 20, 2006 | 11:23 PM
workaholic's Avatar
Default soggy bottom, boy's
I got my 05 500 HO in the swamp pretty deep. I had it up to about the top of the seat, and when I went to back out, the motor stopped. I got of the bike, it floated up, I hooked to a tree and pulled the machine out. When I got her to dry land I checked the air-box and it was dry. The bike started after a little coaxing with the starter/throttle, and ran fine. Went to put it in gear, and got nothing. I pulled the drain plug on the belt housing and out came about a quart of swamp water. After a little drying I put in the plug, and it ran and drove fine.
Do I need to remove the housing and clean the inside and belt? I checked the oil sump and it was OK. I changed all the fluids last week and greased the shaft, ect.
Any advice on other items I should check?
Only a Polaris would have made it through some of the obstacles I survived last weekend [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 21, 2006 | 12:13 AM
dontgetbehindme's Avatar
I would take the cover off just to be sure. Clean it good around the clutchs. I would also wd-40 all over the quad up and around the pod.
Old Jun 21, 2006 | 08:53 PM
workaholic's Avatar
Thanks for the reply.
Mark
Old Jun 21, 2006 | 09:21 PM
spyder6's Avatar
yeh! make sure your clutches are squeeky clean!
ReconBayou
Oct 31, 2022 05:37 PM
badgerboy1
Sep 26, 2017 06:11 PM
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
